Cheese
		ForumMFG said:Whats a time saver? Never heard of that?
A wide belt sanding machine that Michael was referring to.
http://timesaversinc.com
ForumMFG said:As a hobbyist i have time to get these boards in the condition they need to be in.
Cheese said:ForumMFG said:Whats a time saver? Never heard of that?
ForumMFG said:Good tip for the rotex, just to knock off all the dirt. I only had 120 grit last and it took forever to clean it up which is when i decided to use a block plane to clear up most of it.
RKA said:I’d say you definitely got your money’s worth! You’re going to have some fun with all that. The rotex should do a reasonably good job of “cleaning” the boards before running them through the planer, I would think. Got any plans for projects yet?
Michael Kellough said:Only cut off a 1/4” of the ends even if deeply checked. Then paint the ends with a clear sealer, shellac at minimum.
ForumMFG said:Michael Kellough said:Only cut off a 1/4” of the ends even if deeply checked. Then paint the ends with a clear sealer, shellac at minimum.
You said shellac at a minimum, whats your first choice?
Michael Kellough said:ForumMFG said:Michael Kellough said:Only cut off a 1/4” of the ends even if deeply checked. Then paint the ends with a clear sealer, shellac at minimum.
Genuine varnish. Most people coat green wood with an opaque latex sealer to slow drying of the ends to reduce splitting (can’t think of the name now) but your wood isn’t green and I take it you want to be able to see the end grain of the boards in the stack. Don’t forget to sticker the stack (put small sticks between the boards so air can circulate).
jeffinsgf said:Was that the whole batch or is there some left? I'm only a couple hours away.
jeffinsgf said:Well...what you got is all junk, so I'll help you out by hauling it all away. [big grin]
Congratulations. Great score. It would take me years just to figure out what to do with the maple...no project would ever be worthy enough.
Michael Kellough said:Every shop should have shellac on hand. It’s the aspirin of wood finishes.
General info on basic clear finishes.
Zinsser shellac is readymade and readily available. (You can make your own with dried flakes and alcohol from heavy to extremely thin for different purposes). But for sealing wood the ends of the boards it would take a few coats to equal one coat of varnish.
For the board ends I’d just get a quart of any varnish and a disposable bristle brush.
For “cleaning” the boards I like the RAS115 suggestion. It would be good practice to learn how to be productive and maintain fairly good sustainable collection.
