I made a boom-boom
Tim2178
Hey everyone,
I thought I would share with everyone the process of building a boom arm for my CT26.  Since I am only a weekend woodworker, there isn't much extra money for all the Festool products out there.  I figure what money I saved from Festools boom arm I will spend on either an OF 1400 router or a DF 500
domino cutter.
Anyway here are some of the pictures.  I think it turned out quite well.  Fortunately, I run a laser cutter at work and it came in handy when I had to make some of the bracket pieces.
I call it my "Boom-Boom"
Finally a reason to buy a conduit bender!  Not bad for my first bends!
[attachthumb=#]
Mock up of placement of handle
[attachthumb=#]
For a while I thought I was making a chopper!
[attachthumb=#]
Placement of 1" conduit to hold 3/4" conduit boom
[attachthumb=#]
Laser cut 1/4" MDF glued together to make brackets
[attachthumb=#]
Starting to make it look pretty
[attachthumb=#]
First time setting the boom portion into the holder
[attachthumb=#]
I decided to run the 50mm hose through the hose dock
[attachthumb=#]
I used a hole saw to cut hole and bring out the back
[attachthumb=#]
Closer look
[attachthumb=#]
Plenty of room for systainer
[attachthumb=#]
My BoomBoom
[attachthumb=#]
Finished product!  I love it!
[attachthumb=#]
Cool.    For a bit there it looked like you were putting dual exhaust on your CT   [big grin]
BTW the BoomBoom  decal is mint.  Nice job!
Nice Job!
I like how you routed the 50mm hose through the hose garage.
How did you cut the plastic on your hose garage?
-Jeff
Jeff Hein said:
Nice Job!
-Jeff
Thanks Jeff.  I used a hole saw.  It was really simple.  The electric cord is in there too.
Nice job.  You should put a 90 degree bend vac fitting on the front of the vac.  That way you won't have the 10-15" of hose coil sticking out from the face of the unit.
JT
JT
I was wondering if they made such a product.  Where can I get one of those? PVC?
Thx Julian
I think it was at Lowes that I found in the shopvac section a brush that came with a 90 degree elbow. Might have been HD. The elbow fit the CT22 port perfectly. Never used the brush. Think it cost $8-10.
Pete
Very nice! Well thought out, and well done.
The boom boom decal is mint!
How much does the 50mm hose help?
Isn't that like patent infringement or somethin'?  ;)
Just kiddin', nice build. Just one question...where's the nitrous bottle mount?
One suggestion; you need to seriously consider a set of mags with knock offs and maybe some fatty fat tires on the rear. Maybe wrinkle walls? :)
Lazer cutter? Why I ought'a....doesn't Festool make one of them that folds up into a Systainer 4?
Nice set-up.  It has never made sense to me why the boom arm is mounted on the back and the hose port is on the front.  Would it be possible to mount a boom arm to the front of the vacuum?
Tim,
Question about the clamps on the Boom-Boom... what are they and/or where did you get them??
Really nice work; the paint job and the Boom-Boom on the clamp are a nice flair.
Glen
Offshoreman69 said:
Tim,
Glen
The black clamps on the boom part of the "BoomBoom" [smile] are 1 1/4" conduit hangers.  Got them at Menards for like $1.50 for a two pack.  HD and Lowes has them too.
Haha...funny you mentioned that.  I actually made a Festool logo plate as well but figured I better not mount it.  Wouldn't want to disturb the Festool Gods.  I opted for just using the "BoomBoom" logo I created.
Thanks for the compliment.  Not sure if the 50mm hose helps or not.  It was an extra hose that came with a Ridgid Shop Vac from Home Depot.  It fit so I used It.  Plus, I noticed that the Festool boom arm came with a 5' section of 50mm.
Can't hurt I guess
Ok, I used my homemade boom arm with my ct26 this weekend for the first time.  Now I know why anti static hose is all the rage.  Apparently, the small section of 50mm hose that I used isn't anti static!  I kept on getting shocked!!! [scared]
Does anyone know what I can do to fix this?  I remember when I made my cyclone people posted that they ran some inconspicuous wire around the hose that help ground the static.  Or do I just need to buy a small section of Festool anti static 50mm hose?  Where can I get this if so?
By the way...I'm not talking a small zap.  My hair is still on end! [eek]
P.S.  I have to say that the boom arm/dust extractor with the TS55 is single handedly the best part of my shop!  The TS55 was awesome before but now is just beyond the best tool out there!  I also have to say to anyone who is interested in a boom arm that thinks that the cost just isn't worth it...It sooooo is!
-Tim
You can either contact Festool or your dealer and order two (2) of the Festool D50 Rotating Connectors and the length of D50 hose from the Festool Boom Arm -- part number 452386 D 50 MW-AS.
On Edit:   Oh, and you will also need a Hose Connector to connect your existing hose with this new additional section of D50.
