Imperial thickness gauge for Domino with more settings than Seneca one
ear3
New York, NY
I was thinking about getting the Domino imperial thickness gauge from Seneca because I want the ability to do predictable imperial offsets, but noticed that the thickest setting for the Seneca gauge is 1 1/8".  If the Festool OEM gauge goes up to 40mm, why couldn't the Seneca one have gone up to 1 1/2?, which would allow a 3/4 offset (which is what I need for my current project)?  Hey Festool -- I smell opportunity.  And since Seneca already charges $55 for this simple piece of plastic, think of what you guys could charge if you put your green stamp on it!
I could be wrong here, but I think the limit on the Seneca gauge has more to do with the length of the piece than the height.  You need a certain amount of length for each setting, take the available space, divide by length used per stop and I bet there just isn't space left for more positions.
The Seneca gauge changes in 1/8 inch increments, the Festool by 5 - 10mm increments, resulting in greater overall height range.
Ken
I just got the Seneca imperial thickness gauge yesterday. As Ken said, there is limited space. The OEM gauge has larger steps than the Seneca gauge does. The Senca gauge is made to center the bit on standard imperial thickness plywood. Each step is 1/8". The gauge cannot be any longer.
Thanks -- I've done that before, it's just that I wanted an offset that would allow me to achieve a perfect 3/4" offset to fit some 1x material in the lip without any further modification.  Anything is doable given enough time and testing, but part of the Festool edge IMHO is getting presets that save you the normal fiddling and fuddling time.
rvieceli said:
Just use the 40mm setting on your Domino. You'll be only slightly more that 1/32 of an inch off your ideal setting.
If it's important to you and you will be using that offset frequently then I'd suggest making your own. The piece appears to just be a piece of Delrin with the stops machined in. I would not try to recreate the steps but just make a piece that fits into the space and gives you the 3/4 inch you want. Looks like remove one screw and pop in and out.
This seeems like something that could be 3d printed for a fraction of the price being charged.  I like the work that Seneca has done and own several of thei products but $55 for a piece of plastic is a bit excessive
Good idea!  I've been wanting to get into some 3D work, particularly since I have access to the machines and even training through my job.  Maybe this can be my first project.
Edward, I had the exact same issue with the Domino Joiner so I designed a gauge that was first of all an imperial gauge and 2nd went up to 1 1/2" thickness. I went through a lot of prototypes before I was happy with the performance (not as simple as it seems to get it to print properly). Anyways, I've been selling them on Amazon and think it works really well so I thought I would post the link for you. It's half the cost of the Seneca gauge. Imperial Thickness Gauge for Festool DX500 Domino Joiner)
Ah, brilliant. Thanks for the link [member=29138]Steve-Rice[/member] . Gonna try this next time I have production work with non standard thicknesses.
Updated link?https://www.amazon.com/Imperial-Thickness-Gauge-Festool-Domino/dp/B01ASBQQ8K/
Do you make one for the DF 700 ??
