Inlaid-zy Susan
CDM
Here's a little novice hobbiest project I recently finished, re-finished, then re-finished and rubbed out, then had to give away so I wouldn't re-finish it again.
To start with, I read Frank Pellow's thread on the curly maple lazy susans he made a few months back, and decided to try something similar.  As it happens, I was agonizing over making the OF-1400 plunge at my local woodworking store when I found a nice piece of curly maple that was going to leave me just $20 lighter for the visit.  It was 1/4" thick, and when I got out to the car the idea popped into my head that I could use it to make an inlaid lazy susan.  One like the Pellow models, but different.  So I went back in and surrendered my accumulated tool funds in exchange for the OF-1400.  Thank you, Frank Pellow.  Thank you, Festool.
I cut a couple of pieces of my stock of jatoba salvaged from the built-in bookcases I removed from one of our bedroom walls shortly after we moved to our house.  A TS55 and MFT/3 did the job.  In my living room.
[attachthumb=1]
Next, I picked a radius for the lazy susan.  The finished pre-historic edges of the jatoba weren't particularly flush, so I planned on jointing them with the TS55.
[attachthumb=2]
The OF-1400 helped me mill a really wide rabbet on the edges of the boards.  Apparently, rabbets don't interest the cat on the sofa, as she is asleep.
[attachthumb=3]
Clamps are nice.  Here are almost all of mine having a little party.  Maple, meet jatoba.  Jatoba, meet maple.
[attachthumb=4]
One half of the lazy susan blank awaits treatment by Dr. Domino.  You can also see my finish sample on the MFT/3.
[attachthumb=5]
No one likes the big needles, but sometimes they're what's best.
[attachthumb=6]
Then back to the clamps to complete the blank.
[attachthumb=7]
The MFT/3 table helps make a circular pattern so I can try pattern cutting with the OF-1400.
[attachthumb=8]
My rookie pattern cutting went really well until the router tipped just slightly.  I don't have any pictures of the results, so it didn't happen, right?  Thank goodness I used a pine practice blank.
A little bit of hand-sawing at the MFT/3, a lot of hand-sanding, and I was back in business.
[attachthumb=9]
Finally, an almost-finished product.  I stained the top with liquid dye mixed in shellac.  (Thank you Mark Spagnuolo a.k.a. The Wood Whisperer.)  Then I sanded off and re-stained because I wasn't happy with the result.  Then I put down three layers of gloss Formby's tung oil with scuff-sanding between as a top coat, after which I got fancy and tried hand-rubbing with pumice and rottenstone.  I went through the top coats in a couple of spots and had to go through the top-coating and rubbing-out again.  If that makes any sense.
[attachthumb=10]
At last, the lazy susan went off as a gift to family friends who saved us with a last-minute re-gift for an Easter baptism we had to attend.
Very nice pieces of wood. That wood and $20 I guessing you must have been over at Woodworld scrounging around.
Did you set that up as a countertop model or actually install it in a lazy susan cabinet assembly?
I haven't been to Woodworld yet, but hopefully some day soon I'll get over there.  The lazy susan now lives on a moderately-sized round kitchen table.  I suspect that a couple of potential future woodworkers lazily spin it around while waiting for breakfast on school days.  And I have the rest of the source board for some other project.  It's all good...!!!
