chrisrosenb
- Sep 1, 2007
I am working on a kitchen j
I never used that stuff before,but what i would do is make a template after the cabinet and sink are set.Then use the template for the fabricating and cutting.Chris Rosenberger said:mastercabman said:chris,
What kind of solid surface are you using?
I am using Formica Solid Surface material.
junk said:I would be interested in what your solution was to reinforcing the cutout and install when you get the project done. Like I said, I haven't had to install one of those sinks but there is always tomorrows customer. Good luck.
John
Chris Rosenberger said:The cabinets & tops are installed. The farmhouse sink worked out great.
Chris Rosenberger said:Thank you Tim, my wife wants cabinets like these now.
Chris Rosenberger said:You do not see the lights when looking at the cabinets at a normal angle. They are only 7/8" thick.
