FlobeySolo
- Jul 22, 2013
Would appreciate some advice on insulating my basement concrete workshop walls. As you can see I'm badly in need of storage, and this is the perfect wall for cabinets, so whatever direction I take needs to handle the weight of wall hanging cabinets. I also need to accommodate some wiring for extra outlets. The other problem is that I only have 3" of clearance to the door frame opening. Either I build a wall that's less than traditional thickness, say with 1" insulation and 1x2s, shift the door opening a few inches (not easy), or go with a non standard, narrower door opening (less than ideal).
I've seen a few different methods of building walls against exterior concrete, all of which recommend rigid foam insulation:
1. Traditional studs mounted to concrete and headers / footers, with insulation in between studs
2. Foam insulation glued to concrete, then studs built and fastened through foam to concrete and to headers/footers.
3. Some other technique I'm not familiar with...
Note I live in Atlanta, with a mild climate.
Thoughts? Would appreciate any advice you've got... Thanks!
