Distinctive Interiors said:@ Peter Parfitt
Hi Peter, I appreciate Festool MFT tops may not be spot on accurate in regard to the hole diameter and you & I have discussed this in the past.
I found this out when I purchased your Parf dogs when they were first released and they were a loose fit in my Festool MFT top.....
I have since had a full size 2400 x 1200 top made on a CNC machine and lent the CNC guy one of your Parf dogs to ensure the holes he cut were a nice snug fit!......I am more than happy with the result and all the other Festool dogs and clamping elements fit far better than in my original MFT.
Based on this, I would also like to see the option of a longer Parf Fence.
Also, regarding your Parf Guide Sticks, are you suggesting that using them to produce an MFT top is more accurate than Festools original top...??!!!
Regards, Tim.
Hi Tim,
The suggestion about the larger top is nored.
The PGS produced top will use the special drill bit commissioned by Axminster. So, not only an accurate layout but also hole size.
