Everyone,
After some consultation with SMF programmers I have enhanced the search function a bit by creating what is known as a "custom index." From what I understand, this is a complete indexing of every word in the forum, saved to our server. It makes searches more accurate, and also makes them faster.
I've tested out the search function with the new improvements, and I am seeing impressive results. In some cases, it returns hundreds of results in about three seconds.
Regarding search methods, here are the basic principles:
- Use the SEARCH link from the main menu to do forum-wide searches, as shown below:
- Use the magnifying glass [attachimg=2] to also access forum-wide searches.
- Use the text field search feature [attachimg=3] to search just within the topic or board you are presently in.
Most of the time, you will want to use the main-menu SEARCH function or the magnifying glass. The text field is probably an exception.
So, in the end, I believe the search function does work well. I am looking for ways to label the text field area to be more clear, however.
Matthew
