Just wondering how people feel about ripping stock that is already quite narrow, like 2-3". Let's say you have a bunch of boards that are 3-1/8", and they all need to be 3". This would be a very simple and very fast job on a table saw. I am, however, having trouble doing this efficiently and accurately with the track saw.
First, you need some more material with the same height, to put to the left of the stock to cut, so the track has full support (so it wont tilt to the left), and something to clamp the track to -not that big of a deal. The real problem I have is that the material to cut is not really secured in any way. It's not clamped to the track because the t-slots are on the right side of the track. And since you typically start & plunge the saw before the material, then push in to the material, at first there is very little pressure on material (from the track). I experienced on occasion that the material moves right when engaging it.
Does anyone have any suggestions to ensure the material stays put? Some sort of clamping that does not interfere with the path of the cut?
