MichaelW2014
- Jan 3, 2014
see title. thanks
rvieceli said:It does need an adapter. Here in the US it ships with the needed adapter. Don't know about what's included where you are.
Here is the adapter
http://www.amazon.com/gp/aw/d/B003618HSC/ref=redir_mdp_mobile?pc_redir=T1
Edward,Edward A Reno III said:rvieceli said:It does need an adapter. Here in the US it ships with the needed adapter. Don't know about what's included where you are.
Here is the adapter
This is actually different from the one that the 1010 comes with, which is a plastic version. I actually think I'm going to get this metal one, however. I've found that the plastic one is difficult to center using the mandrill, because it's such a snug fit in the base that it doesn't really adjust any further with the mandrill. I just learned that the hard way with some hinge mortises I was cutting.
JPF Woodworking said:In speaking about the inlay "kit" from Whiteside, I too just purchased this set-up. I am hoping to "inlay" some metal laminate (brushed aluminum) into the face of a mahogany cabinet we are currently working on. I get the sense that this inlay kit should would pretty well although I am a bit skeptical on how well the 1/8" up spiral cutter will hold up cutting the metal laminate (phenolic backing)....wondering if anyone has any advice in this regard.....
Now that I wrote all this I probably should have just posted a new thread...sorry to ambush this conversation.....
