it's kind of a tool...
mavrick1903
[attachthumb=#]
[attachthumb=#]
Just for fun. had a USB drive that came out of the outter "case". it's still fine, so I needed a new "case" for it. epoxy was used, and the end is open to the epoxy so you can see the status light.
The guts are a 4gb USB flash drive. cute factor increased as the light on the end for status is festool green. I was not paying quite enough attention when I glued up or the Festool on the other side would have been placed correctly (of course it would only be for a USB port in that position...
I am almost ashamed of how cool I think that is.
I am such a geek.
So how'd you bore out the domino?  Drill press?
I wonder if you could you a 4mm bit for the 10mm domino!!!
Deke said:
Hey, now you are all set to connect a panel to your computer.
Yeah, now you can easilly attach a feed-out table for those extra long sentences.... [big grin]
Regards,
Job
