JAMft - Just Another ...
Irgendwer
Hello,
When reading through the forums, i thought maybe my Version of a Multi Function Workbench might be of interest to some.
Just some pictures to start with:
[attachimg=2]
[attachimg=3]
If i would build one again, i wouldn't put those bevels on the Aluminium rails any more.
They were intended to provide access to all slots on all 4 sides of the table, but they're a mess to cut.
Same goal can be reached by having the long front rail about 12mm shorter on both ends (24mm total).
The profiles are ITEM, Size 8 (mainly 80/40). I just found out they're also available in NA http://www.item24us.com/
The normal Festool clamps fit into the slots.
The FS-Rapid doesn't fit out of the box, but i think you could do it by exchanging the nut.
Max
  • Werkbank.pdf
    Werkbank.pdf
hello just see your table i want one  like this  can you put  the plan for the little piece you use to make the feet folding  please
Nicely done option to the MFT. Looks to be roughly the same
overall dimensions. 80/20 parts are not cheap though, how
does the price of all your parts plus the top compare to a MFT?
What I like about yours is the size can be adjusted to fit the
available work space or if you need something larger for your
projects you can expand it in length or width or both if need be.
