Nimos said:Hi!
I planning to mount my Festool OF1400 in a table (INCRA) with a Jessem Rout R Lift - Prestige router lift.
Is there anyone who fitted the same Router + Lift and can share their experience
/ Nimos
jdw101 said:Nimos said:Hi!
/ Nimos
Just going to say that is a waste in my view. Using a router motor for 200 dollars will net you the same functionality in a table. The OF 1400 is such an expensive router table router. I dropped a large porter cable in my incra table and then I can use the of 1400 for handheld. Just my .02.
I agree. Plus 1400 in that lift must be in fully plunged position at all time. You don't want to leave it like that for long.jdw101 said:Just going to say that is a waste in my view. Using a router motor for 200 dollars will net you the same functionality in a table. The OF 1400 is such an expensive router table router. I dropped a large porter cable in my incra table and then I can use the of 1400 for handheld. Just my .02.
That is probably enough of a reason to skip this option. Thanks!Svar said:I agree. Plus 1400 in that lift must be in fully plunged position at all time. You don't want to leave it like that for long.jdw101 said:Just going to say that is a waste in my view. Using a router motor for 200 dollars will net you the same functionality in a table. The OF 1400 is such an expensive router table router. I dropped a large porter cable in my incra table and then I can use the of 1400 for handheld. Just my .02.
Dovetail65 said:....
My Milwaukee 5625-20 which is 10 years old is a better router in a table than any current Festool router. For 309.00(269.00 on sale every blue moon) that Milwaukee is a heck of a router for a table.
Roseland said:OK, perhaps I'm being dumb here, but why would anyone buy a Jessem Router Lift ($350?) when a $300 Triton TRA001 router has "through the table height" adjustment, automatic spindle lock and no loss of depth of cut?
I agree the OF1400 router is a fine bit of kit (I have one) but nothing would persuade me to put it in a table where the spindle lock and height adjustment are so awkward.
Am I missing something?
Andrew
