Jigsaw with 22mm Hose
semenza
Festool Moderator
Festool Moderator
Fingerlakes Region NYS
   When I reviewed the HSK Sanding Block ( Here )I tried out the 22mm Anti-static hose and the 21.5mm (22mm) Non-Anti Static hose.  The Non-Antistatic is definitely the choice for the sanding block, but at the time I thought the 22mm anti-static might be good with the jigsaw. I had some jigsaw work to do today so I tried it out.
   It is more flexible than the 27mm and I was comparing a new 22mm to a well used 27mm. The 22mm does seem to reduce  "drag" so to speak and make it easier to bend the hose around when turning corners.  I definitely like for the jigsaw. This hose is odd in that it starts out at the vac end at 27mm and gradually  tapers over the entire length to 22mm at the tool end.  The # for the Antistatic  22mm hose is 456745. I think it will be a perfect mate to the Carvex with it's larger DC port that runs straight through the center to the back of the blade. Should be a noticeable improvement to the Trion DC ports.
[attachimg=#]
[attachimg=#]    [attachimg=#]
