leakyroof
- Mar 23, 2011
. Dusty/Dirty 5" shielded caster on the Egg Nest..Note, the thread on these is 1/2" diameter, not the smaller 3/8" that the Nest Casters are from BGG. So, I had to enlarge the factory hole in the Nest to accept the upgraded caster stem.Jim Kirkpatrick said:In my tummy! I forgot to take a pic but it looked amazing. Seared it 2 minutes each side at 700 degrees then 3 more minutes each side at 500. Perfect med rare.iamnothim said:Jim Kirkpatrick said:It really does. I have a 1" drop off my garage and I didn't realize the egg just sits in the nest so when I left it up to clear the drop, it's not happening. I have to bend over and lift the grill by the nest legs. It is currently a very small footprint I should add. Here it is with a couple of 1 lb. porterhouse steaks for the first go round. Frickin delicious!
"Where's The Beef ????"
[member=10952]leakyroof[/member], could you please post a close up image of your casters? Getting down for me is no problem it's the getting back up where I get stuck.
Luke, after seeing your beautiful cart I may have to break down and make one.
Petty, my egg is a large size. Luke's looks the same bu I could be wrong.
