DrD
- Mar 29, 2013
I have a question, and need some guidance.
The attached photo shows how I connected 2 MFT/3 together using Rexroth Bosch Series 45 profiles - one across the front of the 2 tables, and one across the back (not shown) set into the respective V-grooves of the Table Profiles. In one aspect this works great in that both tables are now rock solid, linked together, and the 20mm holes are linear across both tables.
However, if you look closely you will notice 2 Festool clamps on the underside of the profile. This is due to the fact that the 45mm Profile doesn't fit flat with the Festool table edge profiles.
Will the Rexroth 40mm profile fit flush, and not require the clamps, or would the 80/20 40mm profile, or 80/20 15 (1.5") be required? The reason I used the 45mm profiles is that they were free and it kinda proved the concept of what I wanted to accomplish.
Thanks for your help
DrD
DrD
