- Nov 3, 2007
When I bought the house we live in, almost 16 years ago, a considerable amount of "remuddling" had been done. On the surface, most of it looked good and some looked pretty sloppy. A bit below the surface, it almost all looked pretty sloppy. I have been essentially redoing almost all of it over the years.
One feature of the house is a skylight in the middle of the kitchen, a kitchen that is fairly generous for a house its size around here in the '70s. It has leaked a few times and it got steadily worse over time. The leaking ruined the ceiling vault on the low end of the skylight and some of the surrounding ceiling and walls.
[attachimg=#1]
I had to have the roof replaced a while back and had the skylight pulled and reset properly, which stopped the leaking. I since took the vault down to the sheetrock, removing the crapped out joints and tape and started fresh. After some work with a knife and sanders on both the walls and the aluminum frame of the skylight, I got it pretty well cleaned up.
[attachimg=#2]
I removed a pot hanger I made that was along one edge of the vault prior to beginning the project and had another, factory made rack to hang in the middle. I got it off CL unused for $25. It was a distress sale from someone that bought it, waited for a while to install it as their kitchen was being remodeled, and then discovered it wouldn't work.
[attachimg=#3]
If you look carefully in the bottom left of the immediately above image, you can see where the water was causing the paint and plaster of the wall to flake off.
Please also note that the new pot rack is hanging from screw hooks that are sunk into a perimeter piece of solid wood. You might think that I put that there to provide a predictable place to sink the screw hooks. You would be correct. Although, that is just how it worked out...
I originally put them there as a sort of valence to hide a strip of LED lighting. They came in handy to hang the pot rack as well.
[attachimg=#4]
I'm not the best at making a nice finish on a wall. In fact, I'm pretty poor at it but I'm getting better. I'm not happy with how smooth these surfaces are but my wife really likes it and is happy to have it finished. She is, after all, my only inspector and as such, the only one that matters...
[attachimg=#1]
[attachimg=#2]
[attachimg=#3]
[attachimg=#4]
