KA-UG rulers
agehall
I just got my KA-UG set last Friday and spent the weekend playing with it.
I noticed one strange thing though. The extended wings that you can pull out from the main ones, have the rulers in the opposite direction, ie if the main ruler ends at 147cm, the small wing will start at 250 something. Should not the scales match up?
It's the distance to the end stop from the blade. For example if you need to cut 194mm just pull out the extension till it reads 194 flip up the stop and your good to go.
