my kapex will not stay true it goes out of alignment with very little use i mainly only cut 90 degree cuts i cant remember the last time i moved it out of 90
i have contacted festool great service they have sent me two parts both the hold down part and the plate with the markings when it goes out all you need to do is tap the side to get it back in place i have e the hold down screws as tight as you can get them without stripping them the hold down for the saw isn't what is moving its the plate i am close to gluing it down
festool tells me to send it in to them but then i will need to buy a new saw to use while its in the shop and if i do that then i would just end up putting the kapex on cl if i bought a different slider that was accurate i cant have tools that i cant trust to be true day in and day out
guy
guy
