Kapex Adjustment Tip
sancho57
Ive been fooling around trying to die in my Kapex. I was getting good cuts but not as square as Id like. But then Im checking square with a Woodpeckers 1281 square.
Using the 5 cut method I got close, but not close enough for me.
So I went to my resources, Called Tom But hes busy working making a living. He text me and said he'd get back to me tonight. But I didnt want to bother him he works long hours so let him relax in the evening.
So next i called Don at Anderson plywood. He mentioned to take straight edge and check the fence. The fence can go out of square bc of a kick back, which i had a few.
Then I dawned on me Alan told me the same thing. Which I did check and it looked good.
This time I decided to lossen all for bolts that hold the fence in plave use a 36" woodpeckers straightedge  and put pressure on the fence to bring it in line with the straight edge.
It did move a little which means it was out of square. But honestly not enough that could be seen by my eye when i checked the first time.
So there is a method to tight the 4 bolts first tight the outside bolt, then the inside (closest to the blade) next.
So then I checked with the 5 cut methid and it was out. But then when i loosened the 3 bolts on the scale and adjusted them. It came out awesome adjusted.
So after all this babbling what I saying is when adjusting the Kapex, Adjust the fence using a good straight edge first.
It's been a long time since I calibrated my kapex, I only do this when I run into accuracy issues (if it ain't broke...)
But when I did, I did notice that at a certain point calibrating using the 5 cut method, doing the same test from the other side of the blade would get worse when making further adjustments, so at that point I rolled back the last adjustment... (I decided the vallue was already low enough).  (So next time when I feel a calibration is needed, I will get myself a precision straightedge first to get it even better)
(Luckily I haven't experienced any kickbacks (yet) when using my kapex)
it amazed me that something simple like a kick back would throw the fence off. Also how little off the fence was would throw the cuts off even more.
[member=10147]jobsworth[/member]
Do you recall how that kick back happen? Was it because the stock was not tight against the fence? If so, the fence took the hit and voila!
I haven't experience any kick back with my Kapex since I read all the complaints and baby sit the saw  [embarassed]
Thanks for the tip.  [thumbs up]
I’ve had kickback with a number of mitre saws including the Kapex but, it’s always been my fault when in a rush, and not clamping properly, or the stock isn’t tight against the fence.
Adding a kerf insert helps, adding a fence insert as well as the kerf, virtually eliminates kickback if the fences are adjusted properly. Plus the cuts are much cleaner.
[member=66597]Mario Turcot[/member]
The actual cause I dont really remember. Like jiggy said it happens when Im in a hurry to and not paying attention. Since I slowed down even with a lot of cuts and make sure I clamp and hold the material against the fence and slowed down my rate of speed and cut like a sliding compound miter saw and not a chop saw, I havent had any kick back.... yet.
