Kapex DIY Wings or Festool Wings?
Ajax
I should have a new Kapex MFT table arrive today to compliment my Kapex saw.  I have a regular MFT/3 that I will use as an infeed table when I'm in my basement shop, but when I need to go portable around the house I was thinking about buying or making wings for the saw.
Option 1:  Buy the Festool wings (the ones that come with the UG cart, but not the cart itself).  Upside: Light weight, out of the box solution.  Downside: Costly and missing tracks for crown stops and clamps.
Option 2:  Buy the Multiblades hardware for connecting to the Kapex and for the wing legs.  Upside: Less expensive and has a track for crown stops and clamps.  Downside: Need to build it, heavier, and maybe less accurate (depends on my build quality)
Any thoughts on this?  I'm a hobbyist / old home owner.  So when I'm not building furniture, I'm doing projects around the house.
Note: I debated about just getting the UG cart with wings, but I was sold on the different uses I could get out of the Mini MFT (Kapex MFT).
It depends a bit on what you plan to do...for a big project with lots of repetitive cutting to close tolerances the UG wings are very slick.  I have them with the UG cart and I think they make the Kapex that much more capable!  If you are mostly a guy who measures and cuts to a mark then not so much.
Do both. I've got the multi blades bracket and ug wings. It lets you use crown stops and the fence stops. Expensive but really worth it.
Here's an old thread of extensions I made for my Kapex.  It stays in the shop and making them myself saved money but also let me customize them to the space I had in the shop.
http://festoolownersgroup.com/festool-jigs-tool-enhancements/extension-wings-for-kapex/
The wings were originally designed to cantilever off the braces of the Kapex MFT table.  But I ended up redoing the legs to allow for adjustment so I could use them on my MFT or CMS router table.
Unfortunately the pics in that thread are not expandable but I can take new ones if you want details.  They were made before third party hardware was available so I used the Crown Stops.  If making today, I'd use the multi-blades brackets.
neil
