ccarrolladams
- Apr 14, 2010
Ever since I opened my new shop I have discussed my approaches to dust collection on our primary Kapex.
That is my oldest Kapex, one I purchased the first day possible in the USA. It is bolted to a custom bench backed up to a wall. The Kapex is in the middle of a line of saws. A Hitachi C10FCM miter saw is 6' to the left of the Kapex. A General V-154 14" radial arm saw is 6' to the right of the Kapex. The benches under those saws are designed such that the bed height is uniform all along the line. The back rest of all is also in a line, That bench continues 8' past the Hitachi and the General, so dealing with long lengths of lumber is no problem. Behind all three saws there is a typical shop DC shroud. All three dust shrouds have dampers controlled by switches, so they can be opened when a saw is about to be used. The Hitachi and the General have flexible 50mm hoses connecting their dust collection ports to the main DC sustem.
The Kapex has a dedicated Festool dust extractor, attached to it with a 36mm AS hose. In early January we received our Dust Deputy. Because the working height of the bench limits vertical room, the Dust Deputy is on its own shelf between the CT22 and the Kapex. The CT22 connects to the Dust Deputy with a 50mm AS hose. The Kapex and the CT22 are connected to separate dedicated 20a 120v single ph circuits. I have never had a problem letting the CT22 run continuously while making a series of cuts on the Kapex.
On the other side of our shop, in the face frame area, a Kapex belonging to that cabinet maker is bolted to an MFT/3- Kapex stand. Just behind that is a DC shroud. Another of my CT22 is dedicated to that Kapex. Based on the success of the first Dust Deputy another Dust Deputy is on order for this Kapex.
My second Kapex is on a rolling bench we built since it is moved all over the shop. That also has a dedicated CT22, but no dust shroud. So far the amount of bags used by this Kapex is modest and adding a Dust Deputy would require a redesign of the rolling bench.
