Kapex hose
Not that I know.
Two things you could do.
1: buy a cheaper hose and cut it.
2: buy a longer Festool hose and cut it down and have two.
I went with a Bosch hose, and cut it in half.
Btw I went with a non anti static hose.
Charlie
StanB said:
Does any vendor here make the short 36mm hose for kapex?
Hi [member=45856]StanB[/member]
I had a rush of blood a while back and bought a 5m anti static 36 mm hose. I cut about 1.2 m off for the Kapex and the remainder stretches perfectly from my centrally positioned CT to my tracksaw cutting station where I connect it to my TS55.
Although I deliberated on the purchase for a while it has turned out to be a really good investment.
Would there be any value in using a 50mm hose? It seems like the 5’ 50mm hose from the boom arm kit with the 50/36 adapter would work if there is any benefit in 50mm over 36mm.
There would be a slight improvement but a short 36 mm works brilliantly.
Interesting.  Is the hose an anti static hose?  Presumably to get it to work you would need to cut the ends odd and attach festool ends.
RWW
Well poop. Now I have a long 36mm hose...The 2.5" looks interesting option too. Thank you for all the replies
