Birdhunter
- Jun 16, 2012
I was cutting some really dense 4/4 hardwood with the Kapex. I saw the blade actually stop about halfway through the cut. I had wanted to switch to a resharpened blade anyway so went through the blade swap out process.
I found the arbor nut was very loose. I didn't thing this was possible as the rotation of the blade should be tightening the nut.
I swapped the blade and made very sure the nut was tight.
