I'm making a 30" square table, edged with 8/4 Sapele. I have cut the miters on my Kapex. Beautiful smooth cuts, however, when I layout the square - my joints are open. So I did the "5-cut" test and found my saw to be at 0.085° - a little over 1mm over the run of just under than 12" (don't have the numbers in from of me). I understand this to be within tolerance (0.16°, right?), but the sum of 8 cuts over 120" makes for gap that is way too big to accept. So.. Not having tried to adjust the Kapex, am I going to struggle to bring it in that ~tenth of a degree? Or is there some other (woodworking) trick to close my joints up?
I'm a hobby woodworker just getting back to it after a long hiatus. Thanks!
