copcarcollector
- Jan 11, 2013
My next purchase will be the Kapex. I want to put it on the MFT table, but have a couple of questions. This will be in my shop only, not taking the saw to a jobsite.
If you have your 2013bible catalogs handy - please turn to page 47. On the bottom right it shows the Kapex on what I assume is the MFT/3-MINI, the saw basically takes up the entire tabletop. However on page 45, it shows the Kapex on an MFT table, but there is some room in front of the saw where the user has a cutoff and the angle finder sitting there - is that the regular, large MFT/3 table?
I want to put the saw on the larger, and slightly higher, regular MFT/3. This is about the same working height I have my current Makita SCMS at, though the MFT/3-MINI is only about 4 inches lower, I thought the higher table would be good - also if I decide to replace the Makita on my workbench, then I would have another full size MFT/3!
So, aside from the 'which table is shown on page 45' question:
1) If I put the Kapex on the larger MFT, do the rubber feet of the saw fit into holes in the table, or do I need to cut new holes, or just bolt the saw to the tabletop?
2) I know this was discussed recently but I could not find the thread - I want to use the UG extensions as well, am I correct that the legs of the UG will not reach the floor if I have the Kapex on the full size MFT/3?
THANKS in advance---
