Ross 71
- Mar 27, 2016
I've had my kapex 120 for around a year now- and very good it is. I have a slight issue though. When the saw is off and in the fully raised position, the guard seems to stick, and prevent the saw from lowering onto the workpiece. If you push hard, it will yield and the guard moves as it should. If you pull on the guard itself to start it moving out the way, it then operates as it should.
Has anyone else experienced similar? I did a search and found some folks have the guard sticking in the open position, but not in the closed.
I have not yet tried dismantling the saw. It is mostly used (ok. 50/50) with a dust extractor(midi). I have been cutting a lot of tantalised softwood recently, but the problem was there before. I have had an offcut fire up into the blade guard housing which may have done a damage.
Can't think of anything else. Any advice?
Thanks, Ross
Thanks, Ross
