I've seen that others have tried this combination, but did not find the answer to my question...
Could anyone comment if you were able to get the Dewalt Mounting Brackets to attach to the Kapex directly or if you needed to use a piece of ply as a bridge between the Kapex and the stand? The mounting brackets look too short (front to back) for both Kapex bolt holes unless I only mount one bolt per side to the Kapex. One bolt/side would probably hold, but I'd worry about the Kapex sliding on the mount with only a single bolt per side when it is removed from the stand.
Thanks,
Mark
Thanks,
Mark
