Kapex questions
NuggyBuggy
I'm thinking about building a workstation of sorts for my Kapex, and planning to house my benchtop drill press right beside it. I could bolt the DP down so that its base is flush with the Kapex bed, and the surrounding benchtop.  When the table is raised, I ought to be able to cut pretty much any piece of wood I'd cut on the Kapex without interference.
Unfortunately, as I plan this project I am 2 hours away from my tools.
So my two questions:
1- Can any kind soul please tell me how the vertical distance between the bottom of the Kapex, and the main table/bed ?
2- I looked far and wide but couldn't find a Kapex Sketchup model.  Does *anyone* have even a rough model they'd share ?
Thanks !!
terry
Well, I had always heard it was the same height as a Sys 1 - 4".
But...  I just measured my Kapex -
I show 4 1/4 to the top of the table from the Kapex base where the feet drop in the holes.  If you set it flat on a table with no holes, it's about 4 3/8" +/-
I have not seen a Kapex model for Sketchup.
neil
The KAPEX bed is the height of a SYS1 when they are both placed on a flat surface.
A number of websites list incorrect dimensions for a SYS1 (rounding down), so they're not really 4" tall, more like 4 3/8"
The metric dimensions of a SYS1 are 396 x 296 x 105mm *stacked* but they have little feet on them, so when they're placed on a flat surface next to the KAPEX, they stand 112mm tall - the same height as the KAPEX bed.
Hope this helps.
