Anyone have to recalibrate their extension tapes for any reason like after using multiblades crown stops? They’re mounted so well I’m curious if they can be ripped off and reapplied or if they have to be replaced?
If you’re familiar with the multiblades crown stops you’d see they require you to adjust the extensions out about 3/4” from the saw to fit the T-track. So then recalibration has to be done on the tape, not the extensions.
I'm not familiar with those but I do not think that the scales on the UG extensions would be able to be precisely repositioned. I suppose the other option would be to precisely determine the offset on each side on the UG scales and correct your target length accordingly.
