rwtriplett
- Sep 9, 2009
Will the extensions for Kapex UG wheeled stand also work with the Kapex MFT-3? Do you have an imperial scale option?
Tom Bellemare said:It's the same v-groove on the Kapex and the MFT/3.
The MFT/3 is the same height as the deck of the Kapex.
Therefore, the new Kapex extensions should work fine as extensions to the MFT/3....
shoe maker said:it will work with a regular mtf. not the kapex mtf. as for the knob tightening it is a little tight to get the knob tight under the mtf rail but doable i do it all the time
rwtriplett said:Gentlemen, you are correct... the question is: Will the extensions work with the Kapex on the MFT/Kapex instead of the UG cart? Thanks for the help!
jonny round boy said:rwtriplett said:Gentlemen, you are correct... the question is: Will the extensions work with the Kapex on the MFT/Kapex instead of the UG cart? Thanks for the help!
Yes. Absolutely 100%, they WILL work with the Kapex on top of the MFT/Kapex.
Alan m said:will they conect to the side of a mft 3
dbworkshop said:I believe that JMB posted a video where he showed that the locking nut hits the extrusion below the V-groove. My understanding is it won't work without modification.
Dan
dlakeman55 said:Wow! I usually rave about Festool, however I have to say not engineering the UG cart extensions so they work with the crown stop base extensions is a huge oversight by Festool. I won't be buying the UG cart.
Shane,
How about providing feedback to Festool engineering!
