Shane Holland said:Ok, so one of the criticisms that Dave made of the Kapex UG was it's lack of crown stops. Granted there are some options, like he demonstrated. Here's another option that you have if you've got the UG stand and cut crown moulding. Simply flip the left and right extensions and connect them on the opposite sides. You can then use the fence on the back of the extensions to nest your crown. The extensions can be adjusted front to back to the correct spacing needed depending on the size of the crown.
See the photo below for an example.
[attachimg=#1]
This was the tip I wanted to share with you that was presented by a dealer attending AWFS.
Steve R said:Now... what I want and don't understand is why 't the crown molding extensions do not also have the grove on the ends to accept the wings? Seems like a no brainier to me, for a system.
Shane Holland said:Steve R said:Now... what I want and don't understand is why 't the crown molding extensions do not also have the grove on the ends to accept the wings? Seems like a no brainier to me, for a system.
Steve, there's a simple reason. The Kapex UG and it's associated extensions were not developed until well after the introduction of the crown stops. The original extensions made for the Kapex did not require a V-groove to connect to the saw. I'm not denying that there should have been more consideration given to the design. I believe that crown is just not common in Europe and because of that it was given adequate consideration in the design process unfortunately.
Shane
Dave Reinhold said:I think its brilliant. As long as you don't have to cut short pieces that require a stop across the entire saw bed, this should work amazing. Thanks for showing us this.
Dave
