DynaGlide said:
MrToolJunkie said:
Has anyone tried this for the corded saw or is that the version that requires several parts and is not cost effective?
Would also like an answer to this. I have a TS 55 REQ and it works well but wouldn't mind running a narrower blade. It's kinda slow even on 3/4 ply.
Hi, took about one hour and only cost was the new blade.I use a granite tile as a lap stone and glued the paper to it,flat enough for this job.very please with it.[member=61254]mino[/member] the old eq came with a 2.2mm fine,however the pather and universal blade @2.5 and the riving knife@1.8mm+/- .02mm ran just fine minus a splinter guard, riving knife remained functional i.e. don't recall blades ever being stopped by a closed kerf.
