Hi. All. I already have a Kapex 60 e set. I love the compact design , led light. It feels very robust. Well build. Butt when i gonna cut a piece of wood with dimension like 30 cm x 25 cm, 90 degrees. The cut will not be spot on 90 degrees. Already contacted festool ask what to do. They say that i could try to solve the problem by myself. Butt i put some hours in it and i didn't not get the saw cutting 90 degrees. So my is gonna going back to festool. I measured with 2 different squares. One is a starret other one a angulus. Both squares shows the same problem
Here you can see that i pulled out he saw and putt the square against the saw teeth.
Here i dropped the saw back at its beginning and then you can see that there is a gap between the teeth and de square
Here you can see the gap between the cutted piece of wood and the square. At 90 degrees
