Ok I have a question on the execution of lacing in existing hardwood to new hardwood. Question is where do you start in the house?
In other words, do you start with the lace -in then work your way to the wall? Or do you still start at the largest wall and work your way into where you are lacing in?
I have two spots that will be laced in, the opening to the dining room and opening to the living room. Both of which are basically towards the middle of the house. I am having trouble imagining how I would measure accurately enough to get the seams to line up with these two openings if I start at the wall without measuring after each board I lay down and shaving the boards little by little as I go to hide it.
I really want to tackle this hardwood project on my own, but the fact I want to lace-in is the most difficult piece of the project and I flat out refuse to keep the transition strip in. I should also mention the down stairs is filled with cabinets, an island, closets, fireplace, staircase you name it. Going to be lots of cuts. Thinking a pro would lay it out best, but want to try my hand at hardwood install and leave the sand/finish to a pro.
Any advice is appreciated.
