Folks I am looking for a very simple laser level. Basically just a unit that projects a line that is 90 degrees to the surface that the unit is sitting on. I'm not really looking for an actual plumb line but a line that is at a right angle to the surface it sits on. The line also doesn't need to be projected across the room either but fairly close.
I think that means all the self leveling units are out and a manual unit might work.
What I am going to set in on a floor lamp base and use it to transfer locations on the lamp body.
I think this cheap Ryobi unit might work.
https://www.homedepot.com/p/RYOBI-Laser-Cube-Compact-Laser-Level-ELL1500/300038779
Any and all suggestions welcome.
Ron
Ron
