Mahomo59
- Aug 31, 2013
Trying to get better at wip's, I'm an improver.
Small loft room for a house that was built in 1867, so reasonably aged. It's for a young teenage girl, her parents and herself completely designed it...which made it interesting with 3 minds on the task. Any how, all mrmdf 18 mm carcass sprayed with Morrells W/B, 22mm doors with 9 mm panel and 6.4 mm glass. Blum under mounts and blum 110 degree hinges. I'm yet to install knobs as they have not chosen yet, also need to dismantle and re-assemble bed in the NY around the carpet fitters. PITA.
Dry fit
Needed every space while spraying. Spray booth building in Jan.
Loading out hallway
Assembling, my friend Ross on camera.
LR32 every other pin hole
Crawl space storage under bed.
Load testing bed
Trying out the trend scribe, actually really good. May get one to back up old school compass
New carpet to be fitted and knobs to attach...
Mdf with painters grade edge banding. Brilliant! 2 primer & 2 top coat.
Bed has 3 x 100mm ply support pocket holed to the underside running full length.
Kitchen build in the NY, I'll do a better WIP then hopefully.
Dry fit
Loading out hallway
Load testing bed
