Long guide rail storage solution (for me at least)
DonFrambach
For the last several years, I've kept two 55" Festool guide rails hung from a hook in my shop.  Periodically, I would connect the two for long cuts in sheet materials.  I would take them apart for storage.
Recently, I've found it more convenient to keep the two guide rails connected and I've stored them by leaning against a wall in by shop.  I've been concerned that they could get damaged if they were to get knocked over.
Today, I finally worked out a way to hang them from the 12 foot high wall in my shop.  (It would not work for me to simply use a hook in the wall because lining up the hole in the guide rail with the hook in the wall 11 feet in the air would be very difficult.)
[attachimg=6]
First I made a 6 inch disk with a 45 degree taper that I could attach to the guide rail with a 1/4 20 screw and knob.
[attachimg=8]
I then attached matched receiver to the top of the wall in my shop.
[attachimg=7][attachimg=9]
I also attached a spacer with a cutout for my Betterly Straight Line Connector and for the disk (when I'm using the guide rail) within reach lower down.
[attachimg=10][attachimg=11]
Hope this is helpful to someone.
Nice solution for the hole in one shot.
I like it very much. Thanks for sharing
Rick.
I built a false bottom in my van. It allows me to store the 9', 5', and a variety of levels safely.
