Longer D27 hoses than 5m? Or way to join 2 'cleanly'?
jdm5
Fairfield County, CT
Hi all,
I have Rockler's vac hose reel in my shop; works well for my needs but do not like the hose I got with it - it's ~36mm and ribbed which is a problem.
I bought (2) Festool Suction Hose D27/32x5m thinking I could just join them together on the reel - and this kind of works.  But the joint between them (D27 - D32) is pretty large, and intermittently disconnects when I tug on the hose.
1) does Festool make a longer D27 hose, or sell it by the foot?  10m would be ideal.
2) Alternatively is there a smooth coupler instead of the bulky D27 - D32 joint?  I.e. remove both connectors and use some sort of coupler?
Thanks!
There is a thread here somewhere about buying a new vac end for a 27mm hose and replacing 5he tool end on that hose. Then you also buy Festool’s straight connector and the two hoses now go together nice and tight.
          Easiest, cleanest transition is to use a Festool D36 hose going to the D27/32. They are now designed to fit together without any additional connectors. The D36 tool end fits into the vac end of the add on hose. This is for the new smooth hoses.
    Not sure if any connection between hoses will roll up on a reel very well.
