Looking for circular stair design, and building resources.
nydesign
Hi All,
I have a storage loft in my apartment I'd love to build a circular staircase for.
I've searched and have not found any great material, either books, or online.
Ideally I was looking for a source that could provide plans that I could build from.
Thanks for any help!
Jonathan
Thanks Rob,
I'm looking for specific plans, elevations with cut sheets that show exactly how to build the stairs.
There's one site I found, easystair.net that comes close. They have too many restrictions in sizing though.
I'm planning on a steel center column with wood treads, risers, handrail and balusters.
Height from floor to floor is 104", I'm limited to a 48" diameter area.
I don't think that you will find what you are looking for.  In 30 seconds of googling I found that the code for the tread length is now 26".  That times 2 already exceeds your 48" space.  Then you have to allow for the center pole and railing system.
Thanks Peter, I need to check my local code. I think stairs going to a storage space may not need to adhere to code.
I could be completely wrong, I'll make sure before building anything.
That is a distinct possibility.  I just was doing research on alternative stair designs and there is talk about code applying to "habitable spaces".
Hey Peter that is funny...I dug that article up a couple of years back when I was going to do something for my sister and brother-in-law for their outside deck. I liked it because the author needed to put the support structure below the frost line. That's at least 48" deep.  [smile]
