I just ordered some Qwas Dogs,now I am getting ready to have the table top made.I only want to use the table to use the festool clamps for sanding,routing etc.,I have no plans for using the track system.Even though I am just using it to clamp things down with,I will still have the holes drilled 96mm on center.My questions are;
What would be the best material to use,standard MDF,super refined MDF,or Plywood?
What thickness should I use to make the DOGS work best?
I am having a friend cut this out on a CNC,so should I have the holes cut to exactly 20mm?Any tips or suggestions would be appreciated.
