Mauri Motti
- Feb 17, 2011
Thanks Jesse for the greene and greene article. Have saved it right away, very useful.
Jesse Cloud said:If this is your first table, I suggest skipping the breadboard altogether. The idea behind the breadboard is to hide the end grain at the end of the table - not a big deal in my opinion. An alternative would be an edge treatment that de-emphasizes the end grain, maybe a bevel toward the inside or something like that.
amt said:Jesse Cloud said:If this is your first table, I suggest skipping the breadboard altogether. The idea behind the breadboard is to hide the end grain at the end of the table - not a big deal in my opinion. An alternative would be an edge treatment that de-emphasizes the end grain, maybe a bevel toward the inside or something like that.
That is probably a good idea. I was a little worried that I would not have anything to keep the top straight, but I now have an idea: I was planning on using dominos to join the long pieces to each other, mostly for alignment purposes. However, it occurred to me that if I used the largest and longest domino, they could provide structural strength, preventing the boards from cupping. Let's say the boards are 5-1/2" wide. When joining two boards, I would make a mortise as deep as I can go, 70mm, on both boards. I would do this about every 6 inches. The domino would be just slightly smaller length, say 145mm, and the dominos would not be glued in. Glue would only be used on the board's joining faces only. Since the dominos are not glued and slightly shorter length, it would allow the two boards to expand & contract, but the domino would help keep the boards straight. This might even work better than a bread board end, because there are these dominos throughout the entire length of the table and not just the ends.
amt said:That is probably a good idea. I was a little worried that I would not have anything to keep the top straight, but I now have an idea: I was planning on using dominos to join the long pieces to each other, mostly for alignment purposes. However, it occurred to me that if I used the largest and longest domino, they could provide structural strength, preventing the boards from cupping.
Thanks for the link. I had no idea that they were incorporating metal hardware like that into their designs. These days some wood other than Ebony would be used, but the dark wood contrast would still come through as a design cue or look for the piece. [smile]Jesse Cloud said:Poplar and Doug Fir are both good woods. They do have their own personalities, though. Poplar can have areas of green or purple coloring that may show through a light while stain - test first on a piece of scrap. Doug fir needs care when sanding. Parts are somewhat hard and other parts are quite soft (as with some oaks), if you stay in one place too long with the sander, you will take out mostly the soft wood and leave ridges of hard wood. Doug fir is soft enough that it will show dents with use, but that just makes it look like a real piece of family furniture in my opinion. Its worth paying a little extra for a good grade on these woods. Knots can cause all kinds of mischief in a table, especially if they are near the breadboard.
Have you made a breadboard before? They are a little tricky in that they will stay the same length, but the middle of the table will grow and shrink with changes in humidity, so you might want to think through whether you want the breadboard sticking out or the middle part sticking out most of the time. Here's an article that shows a technique that the Greene and Greene style uses to soothe the awkwardness of the joint:
Greene and Greene American Woodworker article
