Beaudreaux JC
- Sep 21, 2014
Hi Guys,
I’ve got a LR-32 question. I’m currently building some upper (garage) cabinets. I’m using the Festool LR-32 System, along with my OF-1010. I’ve chosen the Blum 110° Soft-Close BLUMotion Clip Top Overlay Hinges for Frameless Cabinet (sold by Rockler Item # 32894). The ply is ¾ inch.[attachimg=1]
Here is my problem. I’m using the Festool 491066 5mm Dowel Drill Brad Point Router Bit that is included in the LR-32 system. I know the spear point one is in the pictures, I didn’t want to dismount it and chose its similar sized brother to verify hole diameter. Here’s the problem: but the holes are too large for the (included) screws to attach the hinge plates.
[attachimg=2]
Am I missing something? I’ve already purchased my hinges, and it’s been long enough (master procrastinator) that I’m sure returning them isn’t an option. Is there a larger diameter screw that I can use with the LR 32 system? What is the ‘right’ way to handle this? The easy way would be to just use a self-centering drill bit, but I really want to use the LR-32 (and benefit from its inherent accuracy).
[attachimg=3][attachimg=4]
Any advice or guidance will be greatly welcomed.
Best regards,
JC
[attachimg=2]
Best regards,
JC
