Ok, so I'm thinking about taking the plunge on the LR-32 setup, and I'm debating on whether to buy the 55" rail or the 95" rail. The majority of my stuff consists of upper sections for built-ins, for which the 55" rail would be plenty long, but there's the occasional 7' or 8' tall bookcase that would need the 95" rail to get all the holes drilled in one pass. It'd also be nice to have the 55" rail to use for crosscutting 4x8 sheets, as it would allow me to leave my two current 55" rails ganged together for use in ripping in the 8' dimension. I currently leave them joined together even for short direction cuts, rather than constantly joining and unjoining them, but that gets a bit cumbersome at times, especially for times when I may be cutting a piece thats only say 30" long.
I know the obvious solution is "get both rails", but I hate to drop the $235 for the long rail if its only going to get limited use (it's obviously useless for ripping 8' sheet stock down). I guess the question is, is there a way to use the 55" rail and shift it down the workpiece to continue a row of holes on a long workpiece? I haven't seen anything that would indicate an easy way to do that while maintaining a consistent hole spacing, but maybe I'm missing something??
