I recieved my LR32 router sled and rail the other day, 3 points to note.
The two plastic blocks on the base of the sled have two rivets each to secure them. these rivets stick out proud of the plastic blocks by about 1mm so will mark the work piece.
The sled is covered in sharp edges where it has not been deburred after guillotine/punching.
with the sled adjusted for zero play on the rail once the spring loaded pin has engaged in the rail i measured using a dti 0.3mm of play whilst moving the sled back and forth along the rail. for a £500 system i would not expect any of the above. the guide pin in my opinion should ride in a bush to keep it perpendicular and also would be more accurate than a punched hole
does anyone else see these issues?
cheers
carl (uk)
cheers
carl (uk)
