southern_guy
- Jul 17, 2007
Having purchased the LR32 hole drilling system, it was time to give it a go.
Immediately I was frustrated by the method by which the parallel side fence attaches to the guide rail. The head of the bolt that clamps the fence to the guide rail is hard to loosen and tighten when against the rail. So, I have replaced the bolt with the lever arm bolts made by Kipp. Installing and removing the fence is now a breeze.
The Kipp lever can be disengaged by pulling the head of the lever out, thus enabling it to be used where it is not possible to turn it 360 degrees. It is therefore a very simple matter to adjust it so that it can firmly attach the fence to the rail.
The following photo shows the standard fence on the left and the fence with the Kipp bolt head on the right.
[attachthumb=1]
When attached to the guide rail, you can adjust the lever so that it lies flat against the rail when in the tightened position.
[attachthumb=2]
[attachthumb=1]
[attachthumb=2]
