Mini Me
As suggested above cut the handle off the screw and then you can use vise grips or similar to remove it.
montyss said:I’m wondering if it’s a Posi drive screw. Close to a Phillips but not quite. For some reason I’m unable to post pictures but there are images on Google of them.
ChuckS said:But don't screw extractors work in the same principle?
tsmi243 said:ChuckS said:But don't screw extractors work in the same principle?
I was gonna say yes to this- you're thinking correctly about what they do. The hope is that long before you've actually removed the screw head, the bit will catch, and actually back the screw out for you.
CRG is right tho, the drill bits always seem to work better than the extractors. Paradoxical, eh? The drill bit extracts, and the extractor just drills. ??? If I WANTED to remove the head, I'd use the extractor.
tjbnwi said:I didn’t expect such a simple comment to turn in the conversation it did.
That M4x8 flat head screw threads into a brass draw nut. I’ve broken a few of those nuts, I keep a couple extra in each of the Domino Systainers.
Crazyraceguy said:tjbnwi said:I didn’t expect such a simple comment to turn in the conversation it did.
I have never even touched that screw. Why would you need to? It just retains the lever onto a splined shaft, there is no force against the screw at all.
tsmi243 said:Are we talking about the one where some people have to re-clock the splines, to get more bite? Because I'm one of them- and it DEFINITELY affects the fence slippage. Mine was off a tooth from the factory, and it just barely held the fence in place.
ChuckS said:I'm not saying you don't know but no everyone knows how to use a screw extractor. You don't just put an extractor in the drill and reverse drill!
One needs to pick and match the extractor to the damaged hole, and use the extractor manually.
