DynaGlide
- May 16, 2017
I've owned my LR-32 for a few years. When I went to use it this past time it just didn't feel smooth. The little lever that retracts the pin was rough and it was hard to push the base on the guide rail. I chalked the second issue up to the rail having some uneven thickness where the base attaches over since I took out any slack with the adjusting screws.
The first issue caused me to pickup some Tri-Flow lubricant. I hit the pin on the bottom of the LR-32 plate and the spring mechanism with a few drops. Holy smokes. I wish I would've done that before I had to use the LR-32. It's smooth as butter now. Then I wiped down the guide rail where the LR-32 plate attaches. Same deal, easy sliding.
Sharing this tip with anyone else to hopefully help them out. The bottle is going to last a long time and now I'm going to look for other machines around my shop to use it on.
Matt
Matt
