If you have the LR32 hole drilling kit, you have a ready-made
equivalent to John Lucas' rules, at least for some widths.
There are two side stops included in the kit. The stop is also
available separately as SA-LR32 (485758). (I suggest you get the hole
drilling kit.) Normal use of these stops is to locate the
hole-drilling rail with reference to the edge of the work. They clamp
to the top of the rail (old style or /2) and overhang the cutting edge
side of the rail. Pins are clamped to the bar of the side stop and
contact the edge of the work. The stops are removed after the rail is
located and before the line of holes is drilled. The stops are
replaced on the rail to align it for the next row. The stops are
adjusted before the work begins, and maintain their setting as they
are repeatedly removed and replaced on the rail.
The stops can be clamped on to the rail reversed--that is, overhanging
the other side of the rail. Used in exactly the same way as above,
but to set the rail for the saw rather than for the hole-drilling router.
On old-style rails, the minimum width using the stops is ~7in or
~180mm, the maximum is ~15-1/2in or 390mm.
On the currently shipping /2-style rails, the minimum is ~8-1/4in or
~210mm, the max is ~17-1/4in or ~435mm.
The 14mm across-the-flats hex bar (approx 9/16in) on the stop could be
replaced by a longer bar to cut wider pieces. You could probably at
least double the length of the bar, about doubling the capacity,
before the disproportion would cause other problems.
