LS 130 abrasive sheets (size)
dicktill
Allegany NY
Hi all,
When using the plain rectangular base for the LS 130 sander, Festool's 80 x 130mm abrasive sheets work/fit fine. But what do you use with the larger contour shaped bases?
Thanks, Dick
I use the 80x130 with all of the contour pads as well.. It is a bit small for some of the convex pads and a bit large for some of the concave pads, but it always works
